What is an embedded signal in labview?
Yes, that is what confused me as well. I guess the teacher slipped up and I just have to build a sine wave inside a matrix somehow using the 2D arrays as inputs?
Message 11 of 13
(606 Views)
Well we just learned about that so i'm not entirely comfortable using global or local variables as of yet 😞
Message 12 of 13
(604 Views)
You'll be a better programmer if you remain uncomfortable using those options. The less comfortable you are, the more likely you are to only use them when they're actually needed instead of a using them, as this assignment appears to want you to do.
If you moved a square around, it sounds like the y are treating that square as an "embedded signal." Use that as a foundation and start building the VI
Message 13 of 13
(581 Views)
