12-06-2013 04:38 AM
Hello :
For a costumer I need to work with a NI cDAQ-9178.
What does this device do with it's in- and outputa if the usb connection is disconnect.
Do the digital/analog in- and outputs of the modules keep there last state or do they reset to default.
If the latter, what can I do to reset the in- and outputs to a safe state, given that the cDAQ has no logic like a CompactRIO?
Thank you in advance and kudus will be given!
12-06-2013 03:52 PM
On my quick test on an analog output device it held its last value when USB was removed but AC power remained. I never knew that.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
12-09-2013 01:22 AM
Thank you sir
