Hi Brian,
I am not sure what resource pointed you to using Datasocket Write to change the alarm levels of a shared variable programmatically, but that is not the recommended method.
One resource that you I suggest you check out is the example called Library Generation.lvproj, it is in the example finder under Toolkits and Modules->Datalogging and Supervisory Control->Fundamentals. This shows how to add variables to a library and set the alarms.
For an existing library, please check out this
Knowledgebase article, which describes getting a shared variable reference. One you have the reference, you can use the property "Alarming..." to set Hi, Lo, etc. Then, once you're done, redeploy the library programmatically (Deploy Library.VI).
-Sam F, DAQ Marketing Manager
