What happends if an array runs out of index
Hi I was asked what happens if an array in LabVIEW runs out of index and we keep inserting elements to it. Does it cause a memory overflow? Does it drop the last element in the array? Thanks!
Message 1 of 15
(350 Views)
What does "run out of index" actually mean?
You'd probably run out of memory long before you'd ever "run out of index".  Note, the index for an array is based on an I32 integer.  So that means over 2.1 billion array elements.
Message 2 of 15
(305 Views)
Thank you for your response! I was wondering if we actually runs out of those 2 billion index, what would happen theoretically? I was curious because there is no way for me to test it out on my computer.
Message 3 of 15
(302 Views)
The computer will crash, blue screen of death, followed by a loud bang. Results may vary.
aputman
LabVIEW 2017
LabVIEW Programming
Message 4 of 15
(264 Views)
Challenge excepted...
This is all that happened.
Unfortunately, most readers of this Forum, including some real Experts, have not mastered the skill of being able to read the code that Posters fail to post. If we cannot see "what you did wrong", we are unable to tell you how to fix it. (Bob Schor 28 August 2018)
Message 5 of 15
(245 Views)
That is running out of memory, not index. You can initialize an array with the max value of an I32, none larger. You can use a For loop to make an array, but the For loop's N value is I32 bound also. I don't know how can create an array in LabVIEW with more than I32 max elements. LabVIEW doesn't have 64bit array indexes.
mcduff
Message 6 of 15
(237 Views)
I guess I miss understood the question...
Message 7 of 15
(228 Views)
Hi! What if you use a for loop to fill up an array. Then use the "insert into array" function to insert more elements?
Message 8 of 15
(216 Views)
Let's see, 2147483647 indices, 1 byte minimum per element.
2147483647 x 8 = 17,179,869,176 bytes.  I guess you could do it if you tried hard enough.
Bill
CLD
(Mid-Level minion.)
Message 9 of 15
(182 Views)
Message 10 of 15
(177 Views)
