10-18-2017 05:42 PM
10-18-2017 08:00 PM
What do you mean? Can you post a picture?
10-18-2017 08:57 PM
This control has unapplied changes.save your type def and
Menu file. Apply changes
Honestly, I think that that? Should be one click if the "Automatically update from type def is checked. NI does not agree.
11-28-2017 12:28 PM
This option appears disabled. To solve the problem, I had to drag the controls of the class back to the front panel, and in that way, load correctly. Is there any other way to do this?
11-28-2017 05:24 PM
This happens with a type def control has been modified but not committed. There are two things that cause this.
These problems also break your VI, so you can use the Error window to figure out what your problem is much faster!
