What do you perceive as the size limitations that prevent FieldPoint from working in the system?
FieldPoint was designed with scalability in mind and can handle all of the channel counts that you describe in your comment. In more detail, a single FieldPoint bank consists of one network module and up to nine I/O modules which allows for up to 144 points (9 I/O modules * up to 16 channels per I/O module). On serial networks, you can have up to 25 network modules on the same serial port providing for up to 3600 I/O points per serial port. For ethernet modules, you can have an effectively unlimited number of network modules.
As for safety shutdown logic, all FieldPoint network modules support configurable power-up settings on a channel per channel configurable
basis as well as network communication watchdogs that can set any output (or groups of outputs) to pre-configured values should communication with the host is lost.
For the ability to run independantly of a computer, take a look at the FP-20XX series of LabVIEW Real-Time controllers that allow you to download LabVIEW code directly into the network module. You can use the RS-232 port on the FP-20XX to control a FP-1000 for scalability of I/O points, or you can use the DataSocket VI's to control FP-1600's providing scalability of I/O.
Aaron
P.S. I freely admit that I am extremely biased towards FieldPoint, but I am also very interested in what peoples opinions are as towards it's weaknesses.
