What causes block diagram to expand?
Disables autosizing for all structures on block diagram.
Message 11 of 18
(1,096 Views)
@JÞB wrote:
@paul_cardinale wrote:
This fixes it.
What is it?
Paul posted a VI that recursively turns off auto grow.
GCentral
Message 12 of 18
(1,096 Views)
@crossrulz wrote:
This fixes it.
What is it?
Makes sense.
"Should be" isn't "Is" -Jay
Message 13 of 18
(1,083 Views)
This fixes it.
What is it?
It just turns off auto-grow on all structures.
Message 14 of 18
(1,081 Views)
It's a VI.  Use it to open the VI causing the problem.  Adjust the VI, correct the size (make it smaller), then close and save.
Message 15 of 18
(967 Views)
Could someone post a LabVIEW 2018 (or earlier to help others) version?
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 16 of 18
(938 Views)
Saved for LabVIEW 2016, try if it works.
Message 17 of 18
(921 Views)
Just a new note to this thread,
Found that when using monitors that are 1080P and 32 inch 4K in the same machine.  Was able to create the issue where some of the block diagrams or Front panels in a project would not display. They would display just find when using only one display at either 4K or 1080P.
But not when 1080P and 4K display was used at same time, like I was needing to do. This issue made it so I could not edit the project so it required resolution.
Cause was the selection of what monitor and where the VI should go to when started up or commanded to be displayed.
When had the main monitor to be the 1080P and the 2nd monitor to be 4K, the issue would occur very repeatedly for certain Vi's,
Solution:
Make the main monitor to be the 4K display. After that all VI's (Block and front panel) displayed just fine on all monitors.
Maybe NI as fixed this on new versions. but this is how my LV 2020 operates.
Hopefully this will help someone.
Paul
Paul
Message 18 of 18
(169 Views)
