08-29-2019 02:31 PM
Can someone tell me what the below highlighted vi's are. I have installed the DAQ drivers, but the below two vi's are missing from the Functions Palette. Should I download a different set of drivers? if not, under which section can I find them.
Please help.
My END goal is to build a basic system with PID and DAQmx.
I am using LabVIEW 2019.
Thank you,
08-29-2019 04:21 PM
The selected VIs are:
I recommend you use Context Help (Ctrl + H) to get more information about VIs when you're in doubt of what a function does or how it's called. You can also right click over them and select Explore... to see where they are on disk.
All the best,
