What Does Yellow Mean?
Depending on your labview.ini settings, this method:
can show up as brown (meaning it's private):
NI support tells me that it actually is private, that they've had issues with it, and we shouldn't use it.
Message 1 of 14
(1,797 Views)
What ini file setting does it depend on?
It's brown for me.
It's never a good sign if there is a WARNING in the help...
Message 2 of 14
(1,789 Views)
I think it depends on the relatively secret INI token.
Message 3 of 14
(1,722 Views)
It's brown for me.
It's brown if SuperSecretPrivateSpecialStuff=True.
I've also found some other properties an methods whose color depends on that.
Message 4 of 14
(1,717 Views)
@paul_cardinale wrote:
It's brown for me.
I have always that on.
I suppose all of them should be hidden if the key is false?
Message 5 of 14
(1,707 Views)
I supposed someone with that token could put a private method in their code and it might not be immediately obvious to someone else who was looking at that code.
You can also still access these properties/methods using the Ctrl+B quick drop shortcut but you have to know the full name which can make that difficult.
Message 6 of 14
(1,703 Views)
Probably Ctrl+Shift+B? AFAIK, Ctrl+B changes class.
So those work even if scripting is off? That might come in handy one day... Or is it just the brown nodes?
Message 7 of 14
(1,693 Views)
IIRC enabling scripting just enables your ability to browse to certain classes/properties/methods and doesn't effect operation of any nodes that are already present (I also think disabling scripting might turn blue nodes to the default color).
Message 8 of 14
(1,686 Views)
The different enabling only affects what you can discover during edit while browsing the VI server methods and properties. Once the nodes are placed on a diagram they will work irrespective of any such ini setting, no matter if secret or not (well the scripting one was secret at some point too 😀).
Rolf Kalbermatter
My Blog
Message 9 of 14
(1,648 Views)
At some point I'll try how this all relates to red nodes.
Message 10 of 14
(1,620 Views)
