07-28-2019 03:34 AM
Dear all,
I had configured a webservice inside a server and it successfully can be opened inside local network. Problem have come when i trying to access the webservice from public network. I had made port forward setting in router and configured the port in firewall. I entered the URL http://XXX.XXX.XXX.XXX:8082/SCADA where XXX.XXX.XXX.XXX is my public IP, 8082 is webservice port and SCADA is the webservice name. However, the page prompted out a screen and ask me to key in username and password. I tried admin( password:blank) and the server username but it failed to open the webservice. Here i attached the prompt window. Please help me on this
07-29-2019 06:46 AM
You might try a forum related to your question...
Or give us some link to LabVIEW.
07-29-2019 08:08 AM
The webservice is configured by using LabVIEW .... I am not sure whether forum here can help me or not . Just wanna try my luck to check whether got any person experienced it before 😞
07-29-2019 10:29 AM
Not blaming you, there are some pretty clever people in the forum (not me:smileytongue:). ...
I'd try the username\password on the back of router. You'd probably be able to change it on the router. Not sure if you can disable it.
07-30-2019 02:59 AM
Thank you for your help. I had tried the username and password as you did but no luck for me 😞
08-15-2019 01:38 AM
Have you tried using "admin" as password?
08-15-2019 02:56 AM - edited 08-15-2019 02:57 AM
Yes. I tried combination username, password below:
"admin", "admin"
"admin", blank
computer username, computer password
router user, router password
But all failed to access......
08-19-2019 08:35 PM
Have you try to set a known username and password? You can refer to following KB article.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LgPSAU&l=en-SG
