Webcam with myRIO
I am working on a surveillance robot with myRIO and needed help with choosing a very cost effective camera, under 20$/₹1200. Currently, I am not doing any advanced processing, but I need a camera that gives me continuous video, without any lag. Can someone please help me out with the available choices?
(1,753 Views)
I've got a Logitech C720 that IMAQdx can "see".  Never tried doing this with a myRIO, however.
(1,713 Views)
Do you mean c270, not c720?
That fits within my budget, but won't that slow down the rest of the application due to its consuming a lot of bandwidth and CPU power?
(1,690 Views)
You have to make sure that the webcam is supported by Linux, as the myRIO is running a NI-Linux version
There are multiple documents on applications on myRIO with webcam, search the site.
(1,662 Views)
There is a bit more information in the following community page about what camera specs you might need to look for to make sure it works on a myRIO.
https://decibel.ni.com/content/docs/DOC-30345
In regards to the bandwidth problem, you should be able to configure the camera to run at a lower framerate so it doesn't take too much processing time.
GCentral
(1,653 Views)
Oops.  I just put "Logitech 720" into Google, and when it showed me three inexpensive cameras, I didn't notice that Google was showing me 270, not 720.  That will teach me to trust Google!
BS
(1,647 Views)
I already saw that doc and it doesn't much solve my problem.
As for the frame rate, that's exactly what I don't want to decrease because I want it to look like continuous recording. The c270 looked good, but again it says you need a minimum 1GHz CPU which myRIO does not have. So, is there a camera that can process the image and give it to the myrio to save both bandwidth and CPU power? (That's just a suggestion- the processing thing, if you have something better please tell me)
(1,637 Views)
