Webcam capture/save without $3600 NI-Vision
I would like to use the NI-IMAQ drivers to capture a picture for a test system but my company won't purchase the vision module.  I can't blame them at $3600 per license!  There are some VIs that use system DLLs but they require .net programming, which I am not familiar with.
Is there any way to use IMAQ without parting with all that cash?
(4,012 Views)
Hello Brock,
This tool might be suitable for your needs.    I believe you can download an eval. and check it out.
Patrick Allen: FunctionalityUnlimited.ca
(4,011 Views)
Or check this thread:
http://forums.ni.com/ni/board/message?board.id=200&message.id=23788#M23788
Also you can wait for VAS 2009, where you can use IMAQdx with DirectDraw cams (also not free, but VDM is not required in this case)
Andrey.
(3,992 Views)
Hey Brock,
Andrey is right. The NI Vision Acquisition Software 8.6.1 and the IMAQdx driver that it contains now supports USB cameras (as long as they are Direct Show compliant). With this software, you would be able to acquire images and save them to file. The IMAQdx driver still requires a license. However, because the Vision Acquisition Software does not include any of the machine vision and image processing algorithms, it has a lower price tag. Check out the Release Notes to be sure that this software will work with what you have now.
Hope this helps.
-Ben
WaterlooLabs
(3,965 Views)
This thread is 17 years old!  Incredible that you replied to it but these days plugging in a python script for a webcam capture is far simpler than buying the vision package.
(607 Views)
Just for clarification, BCho's post was from 2009. The post was recently edited by "Content Cleaner", which is what caused it to bubble back up to the top (I assume).
(535 Views)
The Content Cleaner is the account under which posts are edited to fix broken links, either by updating them to new location or removing them if such a location can not be found. It's most likely NI (Natural Intelligence) assisted work after a robot has identified posts with broken links.
Since over a year NI is doing this regularly in batches, apparently often based on a certain topic (I get regularly a whole bunch of them on topics about external code and DLL/.Net interfacing that I often answered on in the past and then for weeks nothing). If you are subscribed to a thread, which happens automatically for the topic starter and by default for anyone who responds on that thread, you receive a notification about Content Cleaner having updated the thread.
Generally, there is little use in commenting on such a thread anymore, especially if it started like 20 years ago. But some people miss the fact that it was just the Content Cleaner doing its thing. And no, there is no reason to suspect this Content Cleaner is some form of censorship. So far it was predominantly about updating links to knowledge base articles and other NI documentation that had moved in the document system on this site and in a few cases removal of the stale link with a notice that the content does not exist anymore.
Rolf Kalbermatter  My Blog
(504 Views)
