01-29-2019 02:24 AM
Hi Chuan19,
thanks for your response.
I had already checked out the links you posted, but was hoping that there might be a better (automated) way.
I could write a GET VI manually which returns all other VIs, including their parameters, but that's a bit tedious and I also have to adapt it each time I add another VI or modify one of the existing ones.
I suppose there are no simple ways to do this?
Also: is there a specific reason why LabVIEW allows the import of .wsdl files, but does not support the creation of them? I understand they use a RESTful architecture for their web services, but that doesn't synergize with .wsdl, does it?
01-29-2019 08:34 AM
Basically, the feature to create web services in .wsdl is not available in LabVIEW, and the RESTful architecture does not comply with the same standard.
