Web Server Configuration
I have Labview 2011 SP1 running under windows XP. We have Microsoft Silverlight 4.1.10329.0 installed by our IT organization. Under Labview Project Explorer,Under Tools->Options->Web Server the Web Server Application Server is grayed out.
Is there a special Something I need to update or buy to enable Web Application Server.
Message 1 of 14
(2,612 Views)
Hi Joseph
The Application Web Server runs as an independent system service. Have you checked to see if it's running on your machine? You can do so by launching the system services configuration utility (Click Start, type 'services.msc' and hit enter). Scroll down to look for 'NI Application Web Server' and make sure that the service status is 'started' and set to automatically start at boot.
Let me know if this helps
It appears that this issue occurs for some people when upgrading from LV2010 to LV2011 or taking some other action which could cause the LabVIEW environment to become corrupted. If you're unable to start the service manually then you will likely need to repair your LabVIEW installation.
Kind regards
Chris | Applications Engineer NIUK
Message 2 of 14
(2,602 Views)
Sorry, I did not notice you replied. I check the application and it says Started and set as automatic.
Message 3 of 14
(2,575 Views)
Accepted by topic author Joseph_Loo
Hi Joseph_Loo
Have you tried repairing or reinstalling LabVIEW?
Kaitlin N.
Message 4 of 14
(2,557 Views)
I do not do upgrades. I unistall labview and re-install Laview. All previous versions are wiped out.
Message 5 of 14
(2,548 Views)
Can you explan the meaning of this statement?
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 6 of 14
(2,546 Views)
I go to Control Panel->Add/Remove Program Delete - Uninstall NI
Run the program for NI and Install the new version.
Message 7 of 14
(2,524 Views)
Hi Hicksc,
I have the same problem as stated above, also done everything you have said but it didn't work for me. I uploaded some snap so that you better understand the problem.
Message 8 of 14
(2,334 Views)
Do you have admin privileges?
Message 9 of 14
(2,315 Views)
yes
Message 10 of 14
(2,293 Views)
