Web Publishing Tool will not work
A few months ago I wrote a program that was to be published on the web. I used the web publishing tool and the program worked perfectly and i was able to view my program from any computer; however, a for a few weeks, the program is not opening on the web and is not connecting to the server and i do not know the reason why. When i see the web configuration i see that it is connected to port 80. When i open the http//:localhost/program_name.html, the html shows a broken link message ("Oops! This link appears to be broken."). In other threads, i read that the port could be busy and I had to change the port number to 81, 82... etc. When i did, the server appeared to be working again but the program would not display; instead, a message in the front panel came up saying that "Client does not have access to the specified VI".
Is there any way I can know what the error is? or how i can fix this problem?
Thank you
Guillermo
(2,771 Views)
Have you taken a look at these two documents?
http://digital.ni.com/public.nsf/allkb/C4127DFFF4152FE3862571DA0006018A
http://zone.ni.com/devzone/cda/tut/p/id/4791
-Zach
(2,752 Views)
