We succesfully built/operated a Labview 6.1 application but have problem when trying to connect E
urotherm 818 controller equipped with OEM serial i/o card. When vi's EI_Bisync READ or EI_Bisync Write were run we got error: "Port 2 config error # 37" Changing port setting to 1 did not help. Also several group # were tried. We have full LV version.We downloaded the appropriate vi's -from Eurotherm's website http://www.eurotherm.com/notes/lab2ei.htm. (similar is at NI's website) Eurotherm 818 was connected with a 3-wire RS cable at com2. MAX says, "device is working properly."
COM1 is operating properly with Bronkhorst Flow-Bus valve bus.
(2,407 Views)
urotherm 818 controller equipped with OEM serial i/o card. When vi's EI_Bisync READ or EI_Bisync Write were run we got error: "Port 2 config error # 37" Changing port setting to 1 did not help. Also several group # were tried. We have full LV version.I've had device errors when the LabVIEW .ini file didn't have the ports configured in it. While NI-DAQ may see the port, the .ini file must also contain the port. In your LabVIEW.ini file, you should have the following line:
serialDevices="COM1;COM2;COM3;COM4;COM5;COM6;COM7;COM8;COM9;\\.\COM10;LPT1;LPT2;LPT3;LPT4"
Hopefully that will help.
Mark
(2,407 Views)
