Way LV front panel windows behavior different?BUG?
when i build a exe with labview,i find front panel looks different with different seting ,see below picture, when i set the VI properties--->windows apperence--->>custom--->>windows behavior--->>default,or set the windows behavior---->>>modal,  this will get very different look on front panel, when set default the border looks not good and very rough ,set to modal will looks good and like a normal windows  exe。but set to modal the minminze buttom will disable,
can  someone help me  out ,any help will be appreciated
(3,787 Views)
Hi dodoo,
it's very hard to tell, what you mean by "rough border" on these blurry JPGs...
Anyway:
It's a Windows© thing to get a small inner border on "default" windows. Each modal window will get this border removed! That's not a special LabVIEW setting, it's part of the OS!
(3,774 Views)
thank you GerdW,
but why other exe build by VB,VC or other language will not looks like Labview EXE,  I think this is  A defect  of  labview.
(3,758 Views)
Internet Explorera  and all other EXE build by VB, VC or other develpment environment  don't have this "small inner border",but all LABVIW EXE have this "small inner border" if set default windows.
(3,754 Views)
Hi dodoo,
see here for an old discussion on this topic...
Does those 2px frame really make up a "very different" look?
(3,735 Views)
It's important to remember that LabVIEW, in order to be cross-platform compatible, uses it's own window drawing scheme and not Microsoft's. All of the other applications you mention do. Personally, I think the differences are minor and not worth mentioning or caring about.
(3,718 Views)
