08-15-2014 06:45 PM
I have some thermocouples attached to a NI9213 and I want to get the data from the waveforms to save to a deliniated text file with no date information just time starting at zero when I press the start button. I can't seem to find where the time date is coming from, so I can't change it. I also can't seem to find the data for the to point as the two data streams are incompatible. I will attach to code any help would be great.
Thanks!
08-15-2014 08:19 PM
The date/time is coming from the T0 in the waveforms. Unfortunately, with that VI you are stuck with the date/time format. You could write your own VI to save the data for you in the format that you want. You would just need to increase the time by the dt information in the waveforms.
08-16-2014 01:24 AM
