Waveform graphs not autoscaling in X
Hello, I have an annoying problem in drawing data with waveform graphs (LV2011).
I will put it in a short statement: I need to compel graphs to properly rescale on the X scale.
Now the details:
I need to show data acquired during a given "event", updating a graph every second. I don't know how long the event will last, but I prefer not to set the X-axis as autoscaled because I don't like the axis rescaling effect. So I initally set the graph as fixed (ScaleFit=0) to a reasonable width in abscissa. When the acquisition ends, I want to show all the data maximized on the available control width, so I set the X axis scaling property to 2. Unfortunately, the graph is often not rescaled. I also tried leaving ScaleFit to 0 and setting the Range:Maximum to the proper value or using the ForceRedraw method, to no avail.
Do you know any trick to compel the X axis to be rescaled?
Paolo
(2,539 Views)
Hi panter,
did you try to rewrite the data after setting the graph to autoscale"?
(2,537 Views)
No, but it seems a good suggestion. I will give it a try.
Paolo
(2,530 Views)
No, GerdW, it doesn't work Smiley Sad
I tried also with ScaleFit=1 (Autoscale once now) and with more complicated pattern (for example reinit to default, then autoscale, then rewrite data). No success.
In all cases, it mainly works (but not always) when I run the program in the LV environment. The very opposite when I deal with an executable.
Paolo
(2,519 Views)
Hi panter,
I only had issues like yours when the EXE was very busy and CPU consuming. Is this the case in your application?
(2,516 Views)
Thank you GerdW for your help. CPU utilization is below 1%.
I will use autoscaling all the time. I don't like the way the graph is compressed during acquisition, but at least there is no risk to miss visualization of some data when the event is especially long.
Paolo
(2,513 Views)
Shame on me! It turned out it was a typical race condition, where a LV2 global may be used before being initialized, depending on the program timing details.
Hence, the graph references array was sometimes empty.
Paolo
(2,506 Views)
