03-02-2010 04:55 AM
Why the time is incorrect in waveform graphic / chart? How to solve it?
When I run the program, I find that waveform graphic/chart show 0 to 20 (time/x-axis) but actual is running 30 second.
03-02-2010 09:07 AM
You need to specify the timing information with "build waveform".
Yik
03-03-2010 06:49 AM
03-03-2010 07:07 AM
The Build Waveform is on the Waveform palette. You can use it to set the dt. It's a fancy cluster. The dt is your loop rate in seconds. I would assume you have some wait or delay function that you are using to set the loop rate.
You can also use a property node - XScale.Range. Offset and Xscale.Range.Multiplier. Look at the example called Real Time Chart.
03-03-2010 08:33 AM
Well, I guess the first question I have is which do you have, a 'chart' or a 'graph'.
That will make a difference when you want to set the xaxis.
