01-25-2021 06:26 PM
Hello, I am getting a horizontal line as the waveform chart is running at fast speeds. Is there a way I can enlarge the scale so that it will display more fine, instead of fast horizontal lines that are difficult to read? In the picture is what I am dealing with... I am using the cRIOMain2 to send data via shared variables to the SingleTunnel2 vi.
01-25-2021 06:31 PM
This would be the intended goal...
01-25-2021 07:23 PM
Charts plot as fast as you send data to them. If you are sampling at 1 kHz, you need to plot 1000 (new) points per second (which is about 20 times faster than you can "see" the data). You can (a) acquire data at a slower rate, or (b) not plot every point. There are two "easy" ways to do the latter -- plot every Nth (i.e. 20th) point, or average (say 20 points at a time) and plot the averages.
