Waveform FFT
Yes, I am reading a raw.dat. This format was took from a laser datas. I am using index to take a one choice of waveform - that is all. I have tried to take all waveforms, but when you are trying to index it doesnt work etc., insted of I need only one choice of waveform. The size is 20.000 points., the frequincy I dont know.  I know how to read a waveform etc., but I dont understand how to manage with dT and number sampling manage all these things to get a FFT. I read a lot, but I dont get it. What do you mean open a single file? Raw.dat is single file.
Message 11 of 45
(2,865 Views)
Bob, I did default and added for new a code. Please look at.
Message 12 of 45
(2,861 Views)
Almost!  In addition to wiring the waveform to a Graph, wire it to a Waveform Indicator (right-click the wire, choose "Create Indicator").  This provides us with a copy of the actual data so that we can look at it and manipulate it with functions.
Message 13 of 45
(2,857 Views)
Here's a Snippet showing what I mean ...  See "First Waveform in Record"?  (This is also what I meant about not needed the Index Array function to give you the first waveform in All Waveforms).
Message 14 of 45
(2,854 Views)
Thank you, I added much more indicators and got a message that the maximum file size. 6milion bytes. How to add in another way?
Message 15 of 45
(2,848 Views)
Bob, I uploaded to wetransfer. Here is a link . Please look at code. Thank you
Message 16 of 45
(2,845 Views)
It should work from uploaded file because here is not possible to upload max 6mb. Please look at code, I dont get how to manage and combine dT and sampling to obtain FFT spectrum (from waveform I dont get how to manage and comabine dT and sampling), because normaly from sin generation it is easy to get a FFT spectrum, but how to get FFT spectrum from waveform. Thank you
Message 17 of 45
(2,838 Views)
I know how to get a FFT from a usal case i.e generate a signal by sin generator, but how to get a FFT spectrum when you have a type data of waveform? What to do with dT? Only that I have is Y and dT and how to get a FFT? Any advices? Thank you.
Message 18 of 45
(2,830 Views)
The dT is in the waveform.
Have you worked with waveforms before?
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 19 of 45
(2,822 Views)
RavensFan, thank you for replay. I worked, but not so much, because I just needed to do calculation etc., but the first time for me when I foresee with FTT spectrum to get from waveform. I hadnot problem to get a spectrum by using sin generator. RavensFan, can you help me? I really need a help.,
Message 20 of 45
(2,818 Views)
