Waveform Chart within a cluster- how to multiplot?
My application uses a Waveform Chart to plot point-by-point data and I need 5 plots of data on it. For a chart by itself I simply bundle the 5 data together and wire it to the chart.
But when the chart is within a cluster (part of a custom typedef control) I cannot figure out how to get the 5 data into the chart for the multiplot. I first create a constant of the control, wire that to the center terminal of a bundle by name and wire the output of the bundle to the control. I then select the Waveform chart as the element I want to write the data to. Just can't figure out what I need to do to bundle the 5 data together to wire into the chart.
Any hints appreciated!
AK2DM
LV8.0.1 on XP, see attachments
(4,566 Views)
Once I replaced your waveform chart with one that had it's type set, it worked as expected.  Alternatively, you could use a 2D array for the multiplot.
2006 Ultimate LabVIEW G-eek.
(4,556 Views)
Thanks Jonnie 5, it seems to suit my needs. I wanted to stay away from arrays since my data I am operating on is better served by point by point.
AK2DM
(4,540 Views)
