Wave form chat not updating
 Dear All
i want to monitor wind speed on graph accordingly to time. i am using different tab pages. the graph is only updating when i currently viewing that page of tab if i be on other page of tab its not updating wind speed. please help.
Asif
Message 1 of 12
(3,821 Views)
Seems to work just fine here. Please attach a simplified version of your code that demonstrates the problem.
Message 2 of 12
(3,812 Views)
Here is an example (LabVIEW 2015). How different is your code?
Message 3 of 12
(3,796 Views)
thanks to replay
1st difference i found that you put tab control out side of while loop while in my project it is inside the while loop.
2nd difference i found that i use get system time which show on x-axis of graph which.
Asif
Message 4 of 12
(3,764 Views)
a lvproj file does not contain any code. You need to attach the VI instead.
It does not matter if the tab terminal is inside or outside the loop. I don't understand what you are doing with the system time.
Message 5 of 12
(3,760 Views)
@Asif138 wrote:
thanks to replay
Asif
Do you realize that you merely attached an "Untitled Project 2.lvproj: file?"
That only points to where code (vis etc...) SHOULD be in your machine.  would you consider >Zip>ping the source code?
"Should be" isn't "Is" -Jay
Message 6 of 12
(3,755 Views)
Message 7 of 12
(3,740 Views)
Why do you refuse to attach something that is actually useful to troubleshoot your problem? (For example, your snippet does not even contain a tab control!).
Please attach a complete VI that demonstrates the problem you mentioned in your first post.
Message 8 of 12
(3,738 Views)
Message 9 of 12
(3,736 Views)
Your VI is password protected and we cannot see the code. Reduce it to a small VI that still shows the problem.
Message 10 of 12
(3,733 Views)
