06-13-2017 05:32 AM
I want to measure water level using Arduino UNO and ultrasonic sensor ((DYP-ME007TX-3pin), Picture attached). I saw several examples but they used LINX. I want to use Arduino option but I failed to make any VI. Any suggestion or help is appreciable.
TIA
06-13-2017 06:47 AM
Arduino is one of the targets of the LINX package. Was there something wrong with the examples?
What do you need help with?
I would suggest that you start by establishing communication with the Arduino, and then with the sensor via the arduino, and then try making a measurement.
Once you have a measurement, you can expand your code to process the results into a water level measurement, probably using some trial and error.
06-13-2017 07:48 AM
Thank you, Mr. Cbutcher
I have attached the example, my LINX option's picture and a sample VI here. Would you check and make the correction, please?
06-13-2017 08:37 AM
06-20-2017 10:02 AM
Hello, Mr. cbutcher,
My ultrasonic sensor is 3 pined. and "MakerHub > LINX > Sensors > Distance > Ultrasonic > Read" is for 4 pined sensor. I also tried the attached VI but failed to get any readings/result..... 😞 😞 😞
06-21-2017 10:18 PM
So assuming that you set up your sensor (with 3 wires) like in the schematic shown on the front panel of the example you uploaded (which, by the way, just calls the VI I mentioned but with the two inputs having the same value 😉 ), can you use the Highlight Execution or a collection of Probes in the lower-level subVIs to determine where the problem is?
06-23-2017 07:28 AM - edited 06-23-2017 07:53 AM
Hello Mr. cbutcher,
I am trying to find out the solution for 2/3 weeks. I bought 3 types of sensors but can't get any result. Now I am really exhausted. this is my last try. I have attached two VI and one pdf here. I have followed the instruction of pdf file but an error occurred. Would you try to find out the problem, please?
TIA
