Want to trigger I/O current, Voltage with the help of toggle button array
I am new in LabVIEW but I need to develop one VI that trigger the Inputs to Voltage/Current to cDAQmx, I got some VIs ready in NI example but I need to make a single VI which can handle I/Os with the help of toggle button array. Please suggest
Prashant
(1,244 Views)
Hi
Is it a software or physical button?, is you are using a button in Labview you can trigger the output with an event structure of value change. Have you used events before?
Jaime Peña
National Instruments Mexico
Ingeniería de Aplicaciones
www.ni.com/soporte
(1,240 Views)
I want to trigger from LabVIEW only, I did some small work on event structure. Could you suggest some refernece VIs you something else? and I have a array of Input buttons.
Prashant
(1,235 Views)
Hi, you can try with the code of this image, just need to find the button that has changed its value and procees it with a case structure. Regardsevent.jpg
Jaime Peña
www.ni.com/soporte
(1,226 Views)
Could you please share the VI file?
Prashant
(1,223 Views)
Why are you using an array of booleans for input?  What happens if you press more than 1 button?
Use an enumerated pulldown selector or radio buttons or just separate buttons you can name and then trigger your event structure with them.
LabVIEW Pro & Measurement Studio Pro (VS Pro) 2019
(1,220 Views)
Yes , he could use independent buttons instead of an array of inputs. And have an event for each button, that will make this easier
Jaime Peña
www.ni.com/soporte
(1,217 Views)
