You could load your data and feed this to an indicator of array of double precision type.
select and copy your indicator and paste this on to the diagram of your VI. This will create a constant.
If you what this to all happen at runtime, thenyou will have to use a Global or local variable and use this as your constant.
Ray.
Regards
Ray Farmer
