If you need to wait for a digital signal before continuing on with your program, the best way is to have a while loop that continuously reads the signal and stops the loop when the signal goes high. You can put this loop in the first frame of a sequence, or you can wire an output from the loop (like error out from the device read vi) into your next step. Be sure to put a delay (100mSec) in your loop so that the loop does not hog CPU time.
