06-29-2011 03:12 PM
This is an interesting subtlety..."If you don't force the wait to execute last..."
How do you force it to execute LAST, as opposed to first, or some other point in the WHILE loop sequence? Is "LAST" the default behavior of this function? Does the programmer have an option about the sequence within the WHILE loop for any of the WAIT functions?
Dave
06-29-2011 03:25 PM
There are different methods for forcing code to run in a specified order.
One could be using the Sequence structures, flat or stacked.
Another way is to use the dataflow, wires, to control what code is executed when. Normally that can be by using the error cluster wire.
If code is NOT connected together, by wires or in a sequence structure, LabVIEW will try to run the code in parallel.
06-29-2011 03:37 PM
And just to give some exsamples:
