03-28-2017 05:51 PM
Hi Everyone,
I want to open the windows touchscreen keyboard when the user press a button on the GUI. I'm not an expert with using windows dlls and send API messages, so I thought maybe you guys can help me to recreate the following C# code functionality in LabVIEW. I found the code here "http://stackoverflow.com/questions/38774139/show-touch-keyboard-tabtip-exe-in-windows-10-anniversary-edition"
Thank you,
[DllImport("user32.dll", CharSet = CharSet.Unicode)]
private static extern IntPtr FindWindow(string sClassName, string sAppName);
static extern IntPtr FindWindowEx(IntPtr parentHandle, IntPtr childAfter, string lclassName, string windowTitle);
[DllImport("User32.Dll", EntryPoint = "PostMessageA")]
static extern bool PostMessage(IntPtr hWnd, uint msg, int wParam, int lParam);
var trayWnd = FindWindow("Shell_TrayWnd", null);
var nullIntPtr = new IntPtr(0);
if (trayWnd != nullIntPtr)
var trayNotifyWnd = FindWindowEx(trayWnd, nullIntPtr, "TrayNotifyWnd", null);
if (trayNotifyWnd != nullIntPtr)
var tIPBandWnd = FindWindowEx(trayNotifyWnd, nullIntPtr, "TIPBand", null);
if (tIPBandWnd != nullIntPtr)
PostMessage(tIPBandWnd, (UInt32)WMessages.WM_LBUTTONDOWN, 1, 65537);
PostMessage(tIPBandWnd, (UInt32)WMessages.WM_LBUTTONUP, 1, 65537);
public enum WMessages : int
WM_LBUTTONDOWN = 0x201,
WM_LBUTTONUP = 0x202,
WM_KEYDOWN = 0x100,
WM_KEYUP = 0x101,
WH_KEYBOARD_LL = 13,
WH_MOUSE_LL = 14,
Solved! Go to Solution.
03-29-2017 01:18 AM
03-29-2017 02:05 PM - edited 03-29-2017 02:24 PM
Hi GerdW,
No, it will run in background if you just use SysExec waiting for WINAPI Message to show up (the keyboard icon on the taskbar). This is the new keyboard for windows 10 touch screen and it's more responsive than OSK.exe, so I am trying to find a way to open when people press on string control boxes. People have already done it in C and C#, but I really don't understand how to use user32.dll to send WINAPI Messages. I found a few samples that are doing other windows messages like muting and volume up and down, but I could not find anything for this one.
Best Regards,
mbadizi,
03-29-2017 02:37 PM
If all you need is bring the other application to the front, you don't have to reinvent the wheel.
You can download:
Windows API Function Utilities (32-bit) for LabVIEW
http://www.ni.com/example/29935/en/
