WHY CONSTANT TDMS STREAMING WITHOUT INDEX FILE?
I run the build-in VI TDMS Streaming - Cont Log and Read Data.vi.
If I deactivate the function of reading after logging, there is no index file generated.
If I want the index file which is generated while logging, how to do it?
Thanks a million.
(2,020 Views)
Hi Guosong,
It is by design that the index file doesn't exist there when you using this feature. I'm a little bit curious why you want the index file in your side? The way to get the index back is that you can open the tdms file with TDMS Open in "Programming->File I/O -> TDM Streaming" menu palette and close it, it will generate the index file automatically for you.
(2,012 Views)
