11-27-2007 01:26 PM
11-27-2007 01:37 PM
11-27-2007 06:12 PM
11-28-2007 09:04 AM
11-28-2007 12:23 PM
11-28-2007 12:41 PM
Error 6 pops up a dialog because you probably have automatic error handling on and because you don't have the error in/out wired in this VI. You could automatically handle the error and continue.
The instrument seems to be old and not compliant to any GPIB standard. It seems it also supports RS-232. You could move it to a serial port and use the VISA Bytes at Serial port to determine whether or not to do a VISA Read.
11-28-2007 12:56 PM
Hi Sandeep,
I would have replied earlier, but I didn't realize the 1100 & 1500 use the same communication protocol. This is a VI that I used a while back to read from ours. Hope it helps.
