[W] Setting TD on serial port high using VISA
I have an evaluation board of an A/D converter that is powered by the TD
line from the serial (RS232) port. Communication with the board is done
using toggeling/reading the RTS/CTS/DTR lines. To power the circuit I need
to set TD high, but I can't find a way to control this pin using VISA,
except sending a break, which will only power the line 250ms - 500ms.
Any tricks?
Ferry Toth
Enraf BV, Delft, Nederland
(3,150 Views)
Hallo, Ferry,
Du meintest am 08.09.99 zum Thema [W] Setting TD on serial port high using VISA:
> the TD line from the serial (RS232) port. Communication with the
> board is done using toggeling/reading the RTS/CTS/DTR lines. To
> power the circuit I need to set TD high, but I can't find a way to
Try "advanced/memory/out port".
Viele Gruesse!
Helmut
(3,150 Views)
Helmut Hullen wrote in message
news:7OV-kdScfjB@hhullen.btx.dtag.de...
> Hallo, Ferry,
VISA:
Will this work with WinNT? That's why I want to use VISA.
Ferry
(3,150 Views)
Hallo, Ferry,
Du meintest am 13.09.99 zum Thema Re: [W] Setting TD on serial port high using VISA:
There are many ways accessing ports under NT. Maybe the newest LabView
version has implemented it - ask NI.
Another way:
"directnt.zip" from the "c't" filebox (www.heise.de/ct)
Some guy from Cambridge (?) UK has sent me "accesshw.zip", it is designed
especially for LabView (but its size is more than 1,6 MB).
Viele Gruesse!
Helmut
(3,150 Views)
get the AccessHW driver from national instruments www-site.
it allows direct register access within winNT.
Regards
Stefan 😉
|| Stefan Tauche Infineon Technologies AG, Munich
|| A Siemens Corporate
|| Email: stefan.tauche@No-spam.infineon.com
\\=========(remove No-Spam from address to reply)==========
(3,150 Views)
