02-24-2010 02:52 PM
I am totally new to LabView, I use Labview 8.6.
I have a PXI-6704 and on three channels I should generate a ramp between 0V and 840 mV under 1 ms and then the signal should stay constantly at 840 mV. This signal is going to start some on-chip oscillators.
I have checked other kind of similar examples as well but as this is my very first experience in LabView I couldn't really understand much of them.
Can somebody please help what I need to use to get the expected signal? Or if somebody has a vi for that...
Krivan
02-24-2010 03:05 PM
02-24-2010 05:39 PM
Thanks! OK, I generate that ramp in another way. Can you give me some ideas/link to threads/vi to get started with the card? I will use it then only for keeping the input signal configurations which are basically costant digital signals apart from some low frequency also digital ones.
So I am interested in how it is possible to set the constant voltages to the cards output.
02-24-2010 06:36 PM
