hello,
I designed code to grab video from an IP camera using IMAQdx and deployed it on a TPC-2512, the app run well but the Image Out shows black screen.
When I run the code on my laptop it works fine (the laptop and TPC are both targets in the same project) and i can see the video from the camera on the TPC using the web browser and when using IMAXdx example app and it also identified on MAX so it's not a connectivity issue.
I also tried to use vision express vision aquisition instead of IMAQdx and it worked on the laptop but not on the TPC (shown black on the image out).
I used LabVIEW 2011 to design the VI on the laptop with NI IMAQdx 3.8.1, the TPC works with LabVIEW Run-time 2011 and NI IMAQdx 3.5 so it might be the problem. The camera I use is AXIS 206 and i enabled free access without password.
I attached a picture of the block diagram.
thanks, Daniel.
