Visa serial communication in event structure
Hi i try to transmit the string in Serial using Event Structure .
Its wirking Fine .. But (Its in ValueChange Event only ).
But i need to use it in Mouse Down Event.
If i use Mouse Down event . it takes double press to do operation. !!!!
(3,557 Views)
Hi saran,
why do you need any VISA communication in your event structure?Why not use a queue driven state machine?
Why do you need to use MouseDown events? What's wrong with ValueChange events?
(3,554 Views)
Hi GerdW,
I need to avoid CPU usage (instead of polling method)
I need to use Event Structure . like data received means . can collect (kind of interrupt  based receiption)
i think u know . whats diffference between Value change Event and Mouse Down (Or Mouse UP) Event
(3,540 Views)
Hi saran,
I need to avoid CPU usage (instead of polling method) … I need to use Event Structure
No need to have the VISA communication in your event handling loop. Use a queue driven state machine…
Yes, I know.
But why do you need to use MouseDown events in favor of ValueChange?
(3,529 Views)
Okay Thanks.
i follow your i dea
(3,523 Views)
