Visa read strange action with Agilent N9320A
Hello, I've got two different results  from Visa read, where it should be the same all the time
1. Using attached VI supplied by Agilent the Visa read do not return proper value after the Visa write (*IDN?) ....  see attached  VI_fail   (line 5.)
2. If I use the Measurement &Automation Visa read works fine....   see attached Measurement &Automation_OK
What's the point of this inconvenience?
Message 1 of 8
(3,243 Views)
You didn't put a termination character such as a carriage return or line feed at the end of the string you are writing in your LabVIEW program.
Message 2 of 8
(3,234 Views)
\n   or    ;     did not helped in this situation as well
Message 3 of 8
(3,225 Views)
Did you enter the \n while the string constant was set for \codes display?
Message 4 of 8
(3,222 Views)
I din'n fully understand what you said, but I did it like this
Message 5 of 8
(3,218 Views)
Your picture of the string constant doesn't show whether you are in normal mode or \codes mode.
Right click on the constant and see which display mode is selected in the right click menu.
Message 6 of 8
(3,211 Views)
.... yes I swiched to \codes mode and added \n at the end of comand, but...
it dont help... and randomly it happens with other commands as well...
....actually the situation is fuzzy and changes all the time. Sometimes it works sometimes it dont, sometimes it works if I restart the analyzer sometimes it dont...
I cant figure it out wether it in My fault or LabView or Analyzer or PC with Win7
Message 7 of 8
(3,186 Views)
I'm not sure in this particular situation but I know when ever I have done VISA writes, I always would right-click on the string control and select '\' codes display.  Then after I type the message I just hit Enter and it automatically puts in the \n.
Jesse S.
Message 8 of 8
(3,175 Views)
