View as icon is evil?
I perused through the CLD sample vi, and ALL of the samples' variables are not in view as icon. I attach one of the sample vi.
What gives?  Is this some kind of secret convention I dont know about? Or is it just a personal preference that makes the block diagrams look more neat? View as icon looks messy? :womanwink:
Message 1 of 8
(4,796 Views)
Many of us started using LV before the View as Icon became available, so we are accustomed to the smaller image.  We never saw any advantage to occupying the extra block diagram space.  So we set the preferences to turn that option off.  LV does allow you the choice. Set it as you prefer. The program performance does not change.  If your organization has a standard for style or usage, you should follow that, of course.
Lynn
Message 2 of 8
(4,784 Views)
"Aristos Queue" did mention one reason to view as icon, which is when doing LVOOP it shows more info about OOP controls. As mentioned before, this "feature" was added only a few releases ago, so many of us are used to the "old" view. It does take up a lot of "real estate" on a block diagram, so that can be an issue.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 3 of 8
(4,769 Views)
Another interesting  blockdiagram Display option since LV 2010 is "View Cluster as Icon" option for Typedef clusters constant.
For big clusters defined as constants on the diagram, i.e. for initializing an Array or a Queue, it can use a lot of block diagram space. Now, you can change it as an Icon, getting the custom icon defined in the Control Editor.
Olivier L. | Certified LabVIEW Developer
Message 4 of 8
(4,763 Views)
Some would insist that you stick with one format or the other, but, as has been hinted above, there are real uses for both modes of viewing.  I use icons only when the icon would give me an advantage over the terminal/cluster viewer.  Icons view is a good idea for classes and clusters (assuming you have taken the time to create good icons).  For almost anything else, I think it eats block diagram space and gives little in return.  However, this is my opinion and is definitely not shared by others.  It really comes down to a matter of taste.
Message 5 of 8
(4,556 Views)
Message 6 of 8
(4,438 Views)
Tools >> Options >> Block Diagram
Very first checkbox at the top under General "Place front panel terminals as icons"  in LV 2010.
Message 7 of 8
(4,434 Views)
Tools->Options->Blockdigram->Place front panel terminals as icons
Regards
Guru (CLA)
Message 8 of 8
(4,432 Views)
