Vibration sensor and I2C
I was wondering if I could get some assistance in communicating the vibration sensor with sbRIO 9633. I haven't worked on any of these before. The vibration sensor outputs a 2's compliment data. How do you interface through I2C? I have no clue how to start.
Here is the specs .. http://www.seeedstudio.com/wiki/Grove_-_3-Axis_Digital_Accelerometer(%C2%B116g)
My application is to measure vibrations in the train.
(4,186 Views)
Can I use the daqmx.. to read from the I2C?
(4,144 Views)
Hi kdm,
have you tried to search for "sbrio i2c"? This will result in several helpful links - and none of them mentions DAQmx for this topic…
(4,139 Views)
Hi Gerd,
Sorry I changed my sensor now (As I felt that the previous sensor is more used for academic grade projects) . The new sensor is an analog sensor.
Here is the specs..
http://www.meas-spec.com/product/t_product.aspx?id=2706#
I need help in calibrating the sensor. There are no equation curves given. It says at zero acceleration, the output voltage is +/-25mV. With this information, is there any possibility to calibrate?
..and can anyone let me know the response time of this sensor? The specs says that the frequency response range is 0-1000Hz (for +/-50g). So is 0.001s the response time?
(4,112 Views)
Hi kdm,
Well, you can correct the offset. That's all you can with this value. No gain correction, no correction of temperature influences, no "calibration"…
MeasSpec also offers several AppNotes on the website you linked to. Did you read those AppNotes? Maybe "Accelerometer Basics" will be helpful for you!
In the first place you should always ask the manufacturer for such details!
As this is a full bridge design it responses (nearly) instantly on acceleration. The more important fact are the allowed frequencies or the natural frequency specified in the spec sheet.
Did you read the spec sheet - and do you understand all of those specs?
(4,107 Views)
