I am modifying a labview program that someone wrote at my work. And I have a probleme with vi hierarchy. A sub-vi appears in the hierarchy named "creneau9c", but I can't find it in the diagram. When I open the main program, Labview is loading it, but in fact, this vi is not needed! I don't know how to remove it.
-- Laurent TERRIER LEGI - Ecoulements Diphasiques 1025 rue de la piscine - BP 53 38041 GRENOBLE cedex 9
> Hello. > > I am modifying a labview program that someone wrote at my work. > And I have a probleme with vi hierarchy. A sub-vi appears in the > hierarchy named "creneau9c", but I can't find it in the diagram. When I > open the main program, Labview is loading it, but in fact, this vi is > not needed! > I don't know how to remove it. > > -- > Laurent TERRIER > LEGI - Ecoulements Diphasiques > 1025 rue de la piscine - BP 53 > 38041 GRENOBLE cedex 9 > > Tel : 04 76 82 51 39 > Fax : 04 76 82 52 71
You could try the "Find" function (after loading the top VI of course). It is also possible that the VI is loaded using the server in which case it will not appear as a subVI. The find should show it to you and you can remove it. Kevin Kent
