I start the Data Socket Server (DSS) programmatically by running the
DataSocket Open.vi. For every connection I have to run that VI. I have
quite a fast computer, but to establish the server for 3 connections it
takes me about 10 seconds! (I use DS just on one machine without a
connected network.)
I also tried to just launch the DSS by using the DataSocket Server
Control.vi. In that case it takes me the same amount of time when I
first write or read to the DSS. So for the 1st W/R function I have to
set the timeout to infinity, not to get an error.
Is this timing normal or am I using the VIs the wrong way?
