VeriStand: The build procedure failed to compile the Simscape model
I am trying to compile following Simscape model into NIVeriStand.tlc file to get dll.
But I am keep getting following error.
The call to NIVeriStand_make_rtw_hook, during the exit hook generated the following error:
    VeriStand: The build procedure failed to compile the model: Simscpae_Model16b. This might be the result of a failed linking or compile operation of the binary file.
If I use Simulink model instead of Simscape, everything works fine. I am also not sure if I can compile Simscape model into Veristand compatible dll. Any help on this issue is much appreciated.
(2,381 Views)
NI has a compiled list of Simulation Modeling environments that are confirmed to work with VeriStand: http://www.ni.com/product-documentation/31488/en/.  I was unable to find Simscape on that list, and therefore don't know if it is possible to make a VeriStand Model in Simscape.
Trevor H.
Technical Support Engineer
(2,350 Views)
