Variable passed by ref to DLL doesn't seem to get re-evaluated properly inside while-loop
I am using LabVIEW 8.2.1. and I use the Application Builder to generate DLL-files from LabVIEW VI's. I would like to create a DLL that generates a square wave on my PXI-4461. I used the DAQ assistant to generate the code for the PXI-4461 and since I want a continuous signal, the code is generated inside a while-loop. I have no problems starting my square wave, but I am unsuccessful stopping it. I know for sure that arrays are passed by reference so I decided to pass a stop flag inside an array to the DLL from my (C#) application. However, the value of the stop flag is not updated inside the while-loop in the LabVIEW-code, I confirmed this by adding a message box inside my LabVIEW code. What is wrong with my code? A picture of my VI is attached and the relevant C# code looks like this:
    private void testButton_Click(object sender, EventArgs e)
      LabViewInterface.startSendingOutSquareWave();
      System.Threading.Thread.Sleep(3000);
      LabViewInterface.stopSendingOutSquareWave();
      MessageBox.Show("Have now tried to stop the square wave");
  public class LabViewInterface
    private static volatile IntPtr stopFlagPtr = Marshal.AllocHGlobal(8);
    [DllImport("SendOutSquareWave.dll")]
    private static extern void SendOutSquareWave(IntPtr stopArray, int stopLength);
    public static void startSendingOutSquareWave()
      Marshal.Copy(new double[] { 0 }, 0, stopFlagPtr, 1);
      Thread workerThread = new Thread(delegate()
        unsafe
        { // Call dll
          SendOutSquareWave(stopFlagPtr, 1);
      workerThread.Start();
    public static void stopSendingOutSquareWave()
      Marshal.Copy(new double[] { 1 }, 0, stopFlagPtr, 1);
Message Edited by arnold_w on 05-12-2009 05:46 AM
(3,433 Views)
I guess I could make a separate (console) application that calls the DLL to start the square wave. My main application would create a new process in which the console application would execute and when the square wave is no longer needed the process would be killed. This would work, but it's a bit of a hack. I would imagine there must be a more elegant solution available?
(3,410 Views)
In order to pass by reference in C# you need to use the ref keyword.
(3,399 Views)
In this case it doesn't make a difference whether I use the keyword ref or not, I have tried.
(3,397 Views)
