11-25-2020 10:19 AM
Hello together
I got here a detector from Varex "PaxScan1308DX" and try to integrate and communicate with it over LabView 2019 64-bit.
I use the "Call Library Function" with the delivered dll "VirtCp64.dll" and use the function "vip_open_receptor_link" as described in the manual but receive "12 -> bad file path" as answer. I do not receive an error from the "Call Library Function".
I am in contact with the Varex support team, but they do not have example code for LabView. I can communicate with the device over their executable Viva64, so cable and Ethernet card is configured well.
What I tried to find in the forums or on google, is just a small example how to open successfully a communication with the device, get for example a serial number, or version information and close the communication/port at the end. Just to have an idea where to start and to not reinvent the wheel.
Does anybody here have a code example for this or similar device? I use it with LV08, eBus GigE, if these information helps.
Thank you in advance.
BR
LN
01-07-2021 06:47 AM
Hi LN,
Were you able to get your dll working in LabVIEW?
I was not able to find any related example using Varex tools execpt for this forum :
in general to work with an external dll, I would advise you to use that tutorial in case you're not already familiar with it :
Call a Dynamic Link Library (DLL) from LabVIEW
Have a nice day,
Junior
01-08-2021 08:49 AM
Hi Junior
Thx for your message. Yes and no - I was able to modify one small part for a test and it worked but I think the time and effort is too high.
So we decided to create an API in C++ which we can call from LabView or from whatever we want.
I found both links as well but it wasn't really helpful. And on the first one, I saw that this way would be a "bricolage" -> is my opinion.
With the API in C++ we have as well the support from Varex which can help us.
Have a nice day,
LN86
05-07-2021 05:05 PM
FYI, I have been able to import that dll, clean a few things up, and get it working for a customer. I can't give away the customer's code, but could repeat the same exercise for another customer or give a few pointers.
09-17-2025 04:12 PM
Hi LN86,
I am also trying to work with a PaxScan1313DX on 64bits labview, trying to move our old windows 7 oem program that we don t have any control over to a new PC windows 11 and hopefully to a custom labview program.
working with paxscanL07 "VirtCp64.dll"
If you could help us we would greatly appreciate.
thanks
Lukasz
10-06-2025 09:23 AM
Hi Lukasz
I am sorry, but I can't help you on this point. As written for 4-5 years ago, we chose the way with an API based on C++ and since we have our own API, we can use it for all different software (internal test benches).
Maybe ask again Varex support team...
Good luck.
Alain
