06-01-2018 02:53 AM
Hi, I am stuck with a problem. I need to find out the values on the axes, when for example y=0 and x is a value, oe the second option when value on axis y is a value not equal to zero and x=0. It is a hysteresis loop and a need values of Hc and Br.
Thank you in advance.
06-01-2018 02:57 AM
Do you have data array? Can you show example?
06-01-2018 03:25 AM
Here is my block diagram in Labview if it will help you.
06-01-2018 04:31 AM
Are you looking for an exact value for one of the axes, or can it be between array elements?
If exact , then use the "array search" to find the index in the first array. Then take the element in the second array with this index. Do it twice.
