Value passed to the Task/Channels In control is invalid
May I assume I am getting this error because my application is looking for non-existent clone names when it runs? Any workarounds for this problem? I'm using 8.6 and Windows XP Pro.
PaulG.
LabVIEW versions 5.0 - 2020
“All programmers are optimists”
― Frederick P. Brooks Jr.
(2,836 Views)
Hi PaulG.,
You are probably referencing a task that does not exist, or has errors. There is a KnowledgeBase article on common DAQmx error codes that may help, as well as an article on error -200428 with DAQmx Base more specifically.
Stephen S.
Applications Engineering
(2,808 Views)
