05-23-2011 03:36 PM
This is not really a LabVIEW question but I did not see another forum for this. Maybe someone in the LabVIEW community can answer this.
I am using TortoiseCVS for my configuration management tool. LabVIEW VIs written using LabVIEW 2010 are OK when added to CVS. But when I commit the file, the VIs are converted to an ASCII format and can no longer be exported as a VI. My work around is to ZIP the VIs before I add them. The problem is, I have to ZIP to add and then UNZIP if I need to edit something. Extra steps that are a bit of a pain. I have searched NI's knowledge base and the CVS documentation with out finding anything of use. Any ideas?
05-23-2011 03:40 PM
We are using TortoiseSVN (not sure about CVS?) but we are able to use LV 8.61 2009 and 2010 (These are versions I have used under this SCC) with no problems.
