03-19-2020 02:44 PM
I can't figure out why my VIs do not stay in a vritual folders as I command them to!
I have a project with a library (lvlib).
The library contains couple of VIs. I created some virtual folder structure in this library and I want to place those VIs in that structure.
All goes fine till I close and reopen the project.
All VIs are back in their original spots, not in my perfect virtual folder structure...
It's late, I'm tired after work so my brain has some lag. Help me out here...
Attached is a simple example of my issue. Try to move VIs in the lvlib to the virtual folder...
The only way I found is to remove the VI from library and add it in specific folder. But that does not answer my question!
I'm using LabVIEW 2018 SP1 f4 if that makes a difference...
03-19-2020 03:02 PM
Works OK for me.
03-19-2020 03:07 PM
I assume you meant to say: "All goes fine till I save, close and reopen the project..."
03-19-2020 03:07 PM - edited 03-19-2020 03:11 PM
@paul_cardinale wrote:
Works OK for me.
What do you mean? That it works as it's supposed to or it works as I would like on your side?
@altenbach,
Right, forgot to mention about saving it 😉
03-19-2020 03:25 PM
Works fine for me as well. I can move both of the VIs into the virtual folder, and when I save, close, then re-open, it stays in the structure.
Are you sure you are opening the same project that you are saving?
03-19-2020 03:33 PM - edited 03-19-2020 03:37 PM
Yes, I'm pretty sure. I've made many attempts before I started this thread to be 100% sure that I did not do something stupid.
So it seems to be an issue with my PC. I will try to find a different PC with different version of LabVIEW to see if I can reproduce it.
EDIT: I found another one and it behaves the same. Unfortunately it is the same LabVIEW version (2018 SP1 f4). I will run an installer of LV19 to see if it helps.
03-19-2020 04:05 PM
03-19-2020 04:14 PM
Any chance you're saving to something like a source code folder or a Google Drive backup folder?
03-19-2020 04:25 PM
Is it some sort of auto-populating folder?
03-19-2020 04:31 PM
