10-06-2020 08:42 AM
Hi sir gud evening small problem please solution
i have my screen display at 1366*760 but accessing the funtion according to the 1152 * 864 not accessing the funtion again uninstalling software again update but not solution sir so please me to get it
screenshot adding this problem sir plz help me solution
10-06-2020 09:43 AM
Did you look at the last part of the dialog box where it talks about the taskbar?
If you auto-hide the task bar (which seems to be always on in your screen shot), does that solve the problem?
10-06-2020 10:15 AM
Your vertical display setting of 768 is not enough for Vision Assistant. Choose a display setting with a higher vertical resolution, which is at least 864, such as 1600 x 900, which should give you a similar aspect ratio on your screen.
10-16-2020 08:38 PM
Is there a bug with the language in that dialog box.
"it should be 11542 x 864 or later" Shouldn't that say "larger"?
