05-02-2016 06:52 AM
I'm using both Digital and Analog Sensors . And depending upon whichever port the user selects I am displaying the waveform on a wavefrom chart.
i want a transition in the waveform chart axis when the user shifts from analog to digital so that the waveform is clearly visible. This is not happening. how do i customize my waveform chart.
Tha analog readings are somewhere between 200 and 400 and digital values are 0 -1. My y axis range is 0 to 1000.
So in a nutshell i want a clear transition from analog to digital or vice versa so that the user can clearly see the graphs.
Note. if i set y axis to autoscale it will give the result but a haphazard graph is coming which is not worth seeing.
Thanks a lot in advance 🙂
05-02-2016 07:03 AM
I think waves are powerful!
05-02-2016 02:44 PM
You can use property nodes to set the Y-axis scale. The properties you care about are Y Scale->Range->Maximum and Y Scale->Range->Minimum.
